 Forum de l'association French-Drift-Community • Consulter le sujet - Jacob & Co. Epic X Chrono
Message par jadipe » 29 Mai 2025, 07:17
Jacob & Co. Astronomia Sky is really a high-end high quality watches replica along with great innovation and complexness. The following is a detailed introduction through the dimensions of its motion, appearance design, functional functions, etc .:
Movement
Model and structure: Built with Caliber JCAM11 movement, this is a complex manual winding movements with 395 components along with a unique four-arm rotating system design. The entire platform moves around the central axis as well as completes a full rotation each and every 20 minutes.
Precise timekeeping: Equipped with the three-axis tourbillon, the first axis of the tourbillon takes one minute to rotate once, and also the second axis takes a minute to rotate once. Additionally , the third axis brought by the working platform rotation makes the timekeeping much more accurate and can effectively balance the influence of the globe's gravity on the movement.
Power reserve: It has a power reserve associated with 60 hours, providing steady power support for the numerous complex functions of the watch.
replica Jacob & Co. Epic X Chrono
replica Breitling Avenger Hurricane watches
Appearance style
Case: The design is actually inspired by the astronomer's observatory. It uses a streamlined rose gold colored or white gold frame, having a large area of sapphire crystal, including the huge sapphire curve on the top and the whole sky-blue bezel surrounding the watch entire body, presenting a transparent views, like a miniature cosmic statement window.
Switch: Made of blue titanium, it really is etched with exquisite groupe patterns, as if moving the celebs in the night sky towards the wrist. The earth, moon along with other celestial bodies on the switch are presented in 3d shapes, vivid and realistic. replica Breitling Avenger Hurricane watches
Strap: Usually paired with a good alligator leather strap, like the classic blue alligator leather-based strap, which is soft and comfy to wear, complementing the metallic material of the case and featuring the luxurious texture from the watch.
Practical features
Astronomical screen function: There is a central planet model, covered by a hemispherical sapphire crystal cover. Our planet model can complete a rotator within 24 hours, clearly displaying the alternation of night and day. At the same time, it also has a celestial satellite display function. The celestial body overhead is made of a 1-carat white-colored diamond, cut with a distinctive 288-face Jacob-cut, and revolves once every 60 seconds in order to simulate the movement flight of the real moon. swiss replica watches
Unique time function: Its small second-hand is uniquely designed, situated in an eccentric position, formed like a spaceship, and goes around once a minute around the main axis. The hour and also minute display is located one the other side of the coin arm of the rotating program. Through the patented differential program, the dial is always straight and readable when the software rotates.
Starry sky and month show: The rotating back dish on the back of the activity is made of blue titanium, etched with the zodiac constellation design, and completes a full revolving every 365. 25 times, which can show the changes in the sidereal year. At the same time, there is a 30 days display function at the bottom of the watch case, presenting a unique astronomical work schedule indication function.
replica Jacob & Co. Astronomia Sky
replica Greubel Forsey GMT watches
swiss replica Watches
jadipe
Message(s) : 13
Retour vers EVENEMENT FDC
