 Forum de l'association French-Drift-Community • Consulter le sujet - [VDS] S13, S14, S15, R32, R33, R34 parts
Message par BH1 » 04 Août 2012, 11:58
Hello guys,
some of you might already know my project which i introduced in my project thread here.
However due to high tuition fees of my next university i have to sell the car to finance my further studies.
Nearly all parts are brand new, that means that they were test fitted but were never runned in the car.
If a part is used i will mention this and the condition of the part.
Parts of these manufacturers are/were for sale: Apexi Cusco Greddy HKS Blitz Nismo Tomei Blitz
Shipping costs (insured) are depending on the weight:
France: 15,00 - 25,00 EUR (Please request for exact shipping cost)
You are also welcome to pick your desired part up in the near of 76133 Karlsruhe, Germany (70km north of Strasbourg).
If you have any questions or if you are interested in the parts just let me know by a private message.
BH1
Message(s) : 66
Re: [VDS] S13, S14, S15, R32, R33, R34 parts
Message par BH1 » 04 Août 2012, 12:02
BH1
Message(s) : 66
Message par BH1 » 04 Août 2012, 12:04
6x Bosch Injectors 440cc (480cc 550cc 600cc) Top Feed, EV 6 CS incl. Plug . Price 490,00 EUR (Bosch Injectors + Manifold Confersion = 1380,00 EUR)
These injectors are brand new and fully functional and are originally beeing used by Porsche in the GT3. Original price was ~700,00 EUR, Bosch part number 0280156012,
high impedance 12 Ohm, max. 8 bar fuel pressure, can be used on 6 bar pressure all day long, the performance depends on the fuel pressure:
453cc @ 43.5 psi/3 Bar (standard-pressure), max. ~400hp,
480cc @ 49 psi/3.4 Bar, max. ~450hp,
555cc @ 65 psi/4.5 Bar, max. ~500hp,
600cc @ 76 psi/5.2 Bar max. ~550hp,
640cc @ 87 psi/6 Bar, max. ~600hp
RB20DET & RB25DET NEO - plug & play
RB25DET - you will need a Greddy/Freddy Inlet Manifold + top feed rail + use included plugs
RB26DETT - you have to remove/bypass the small resistor pack see here
Datasheet downloadable here, a good FPR is for example the [url=http://www.isa-
racing.com/index.php/cat/c667_Motorsport-Benzindruckregler.html]"FSE Motorsport 6 Bar"[/url],
every good mapper can work with these injectors, same performance and quality as Nismo injectors but much cheaper.
BH1
Message(s) : 66
Message par BH1 » 04 Août 2012, 12:07
[Cooling]
Custom made 3"/76mm Ladeluftkühlerverrohrung. Price 49,00 EUR
[Brand new/only test fitted] This piping is ideally suited for RB25DET (with Freddy/Greddy inlet manifold and top or low mount urbo) or RB26DETT (for top mount turbo) swaps in your S13/S14/S15.
The piping will suit any FMIC and includes a fixing point for a HKS SSQV and a conneciton for the boost solenoid of your boost controller. Samco's and hose clamps aren't included.
Samco's 3x3" (76mm) straight, 1x 90° reduction angle from 2,5" (65mm) to 3" (76mm) Price 5,00 EUR/piece for 76mm straight, Price 29,00 EUR for reduction angle
[Brand new/only test fitted] Hose clamps included (not with 90° reduction angle)
[Electronics]
RB25DET Power Transistor / Ignition Amp / Transistor Ignition unit / Ignitor Amp 22020-97E01. Price 49,00 EUR
Oil Pickup (RB25DET) Price 15,00 EUR
Delta-R exhaust gas temperature sensor (EGT Sensor) TS-200 + fitting Price 45,00 EUR
brand new sensor.
Here you can buy a matching digital exhaust gas temperature display for 105,00 EUR.
[Suspension/Steering]
GP-Sports G-Master Hyper Knuckle Kit. Price 490,00 EUR.
[Brand new/only test fitted] Made for Drifting to dramatically increase the steering angle. Very rare and worldwide seeked. Plug & Play with S14's & S15's, will fit S13's also with front S14 knuckles and bearings/hubs.
You will find more information about them here: 1 [url=http://www.chromjuwelen.com/de/partner-und-mitglieder-blogs/jpcnews.blogspot.com/gp-sports-release-
hyper-knuckle-kit-for-silvia/laurel.html]2[/url] 3
BH1
Message(s) : 66
Message par BH1 » 04 Août 2012, 12:11
More links for GP Sports Knuckles: 4 5
Engine/Drivetrain:
New OEM Clutch Cover (only 8.000km old, extremely good condition) - 50,00 EUR
Option 2: Pressure Plate + new Sachs clutch discs and release bearing = 190,00 EUR
The clutch pressure plate was used by an retired old man at stock power for just 8000km.
Perfect for AT to MT conversions or simply to replace your old and worn clutch.
S14/a Ambient Temperature Sensor, Außentemperatursensor - 20,00 EUR
Interior:
OEM passenger airbag -49,00 EUR
Various:
R33 Front Crossmember Price 69,00 EUR
Ideally suited for RB & JZ swaps in S13/S14/S15. The crossmember is used but rust was removed and POR-15 rust preventive paint was applied.
S14/a Front Crossmember Preis 49,00 EUR
Ideally suited if you want to install a non SR engine and would like to modify the crossmember to achieve enough clearance to the oil pan.
Alternatively it is also suited for rust removal and to apply rust preventive paint or if your crossmember was damaged during an accident.
S14/a rear subframe Preis 49,00 EUR
Perfectly suited for rust removal, to apply rust preventive paint and to install subframe bushings or if your crossmember was damaged during an accident.
BH1
Message(s) : 66
Message par BH1 » 16 Sep 2012, 12:01
: up :
BH1
Message(s) : 66
Message par xurple » 19 Fév 2025, 11:07
Message par xurple » 06 Mars 2025, 11:41
Message par xurple » 06 Mai 2025, 20:49
Message par xurple » 06 Juin 2025, 19:24
