 Forum de l'association French-Drift-Community • Consulter le sujet - How to Farm 24 Elden Ring Runes Using Terrain Advantages
Message par Ruckusflare » 01 Juil 2025, 08:15
Farming runes in Elden Ring isn’t just about grinding—it’s about strategy. Many players overlook one of the most potent tools in their arsenal: the terrain itself. From cliffs to choke points, the Lands Between are filled with environments that can make farming faster, safer, and even more satisfying. In this guide, we’ll explore 24 rune farming opportunities where smart use of the terrain can turn the odds in your favor.
1. Stormhill Cliff Push
Northeast of the Warmaster’s Shack, a group of soldiers patrol near a cliff edge. With proper baiting, you can get them to follow and fall to their doom. Minimal effort, great reward.
2. Bridge Ambushes in Limgrave
The broken bridges often have soldiers and wolves grouped tightly. Use AoE spells from a safe distance, especially from elevated terrain, to thin them out without being overwhelmed.
3. Caelid Swamp Ledges
Caelid’s poison swamps are hazardous, but the ridges surrounding them offer vantage points to snipe at wandering enemies like the Cleanrot Knights. You farm safely without ever setting foot in the muck.
4. Liurnia Ruined Towers
The crumbled ruins of Liurnia house sorcerers and undead. Lure them into narrow stairways or drop down ledges where they can’t reach you but remain within spell range.
5. Cliffside Archers in Altus Plateau
Some of the best rune yields come from farming the Leyndell knights. If you lure them toward the steep cliffs west of the lift, they’ll often fall with little coaxing.
6. Mountaintops of the Giants Drop Ledges
Here, runebears and trolls wander close to edges. Aggro them, dodge smartly, and let gravity do the work. Timing is everything.
7. Mausoleum Soldiers Pit Trap
Near the Wandering Mausoleum, you’ll find tight rock paths surrounded by drops. With a little patience, it’s easy to corral soldiers into falling to their death.
8. Academy Gate Town Floodplain
The shallow waters offer slow movement for enemies, but you can use broken rooftops and elevated stonework to kite and kill without retaliation.
9. Siofra River Platforms
This area has many narrow bridges and elevation gaps. Use ranged attacks or spirit ashes to lure enemies across narrow paths and knock them off with forceful skills.
10. Crumbling Farum Azula Tornados
Yes, it’s endgame, but the broken walkways and aggressive beastmen here are perfect for terrain traps. Let them leap into nothingness while you keep your distance.
Terrain-Specific Tips
Use Gravity Spells: Gravity well and Rock Sling can pull enemies toward cliff edges and interrupt charge attacks.
Spirit Summons Help: Tank summons like Lhutel or Ancient Dragon Knight can keep enemies distracted on edges.
Keen Awareness: Always scout areas for ledges, slopes, or elevation drops. Many enemy AI scripts don’t handle verticality well.
A Balanced Strategy
Terrain farming isn’t about brute strength. It’s about finesse. You’re reducing risk, conserving resources, and speeding up your rune intake all at once. While it may not always be as flashy as a full-on boss takedown, it’s undeniably efficient.
And if you're looking to enhance your builds even further, the best site to buy Elden Ring Runes and the best site to buy Elden Ring items can offer what you need to test out new strategies quickly. Of course, that doesn’t replace the thrill of discovering clever farming spots—but it sure helps with experimentation.
The Lands Between reward not just power, but insight. When you start seeing the terrain as part of your toolkit, farming becomes far more than repetition. Try out these 24 terrain-based rune farming methods, and you’ll not only get richer—you’ll become a smarter Tarnished.
Happy farming, and may your footing be as solid as your strategy.
Ruckusflare
Message(s) : 6
Utilisateur(s) parcourant ce forum : Majestic-12 [Bot] et 3 invité(s)
