 Forum de l'association French-Drift-Community • Consulter le sujet - Level Ball Handicap (Draw No Bet): What It Is and How to Bet
Message par wintips123 » 27 Mai 2025, 10:31
Level Ball Handicap (Draw No Bet): What It Is and How to Bet Smart
Often appearing alongside Asian Handicap options, the level ball handicap—also known as Draw No Bet—is a favorite among many football punters. With its straightforward rules and reduced risk factor, it’s a go-to choice for those who want more balanced wagers. In this article, WinTips will walk you through the key features of this betting type and share practical tips to help you place smarter bets.
What is a level ball handicap?
So, what exactly is a level ball handicap?
In reality, the level ball handicap (also known as "draw no bet") is a commonly used type of bet, no less popular than the Asian Handicap. It is applied when two teams are evenly matched in terms of strength and performance. Therefore, in matches where this bet appears, there will be no favorite or underdog — both teams start on equal footing.
This type of bet usually occurs in high-profile matches between equally strong teams, such as Manchester City vs. Manchester United, or in major tournament finals like the World Cup, Champions League, or Euro.
In addition to the level ball handicap, you might come across the term “quarter ball handicap” (0.25 handicap). While similar to the level ball handicap, it differs in payout. If the match ends in a draw, the bettor backing the underdog loses half the stake, and the bettor backing the favorite wins half the stake.
Features of the Level Ball Handicap
As shared by the leading betdirect bookmaker W88, you probably now have a basic understanding of what the level ball handicap is. The following features will help you better grasp this type of bet to make quicker and more accurate predictions:
The level ball handicap appears when both teams have nearly equal strength and balanced squads. Both teams must also be in stable form, as this type of bet doesn't stand alone like other handicaps.
This type of bet is used when two teams are evenly matched.
The level ball handicap is often accompanied by other betting types such as the 0.5 handicap, live (in-play) bets, or the 0.25 handicap. This gives punters a chance to choose the most effective betting strategy.
When Does a Level Ball Handicap Occur?
There are several scenarios in which a level ball handicap might be applied, but three common outcomes typically help punters read this type of bet more easily:
If the favorite team wins: Bettors who backed the favorite win the full amount.
If the match ends in a draw: All bets are refunded (stake returned).
If the underdog wins: Bettors who backed the underdog win the full amount.
Proven Tips for Betting on Level Ball Handicap
To profit from level ball handicap bets at reputable bookmakers, you must understand the rules and be willing to take calculated risks. Experienced players often share that this bet has a lower win rate compared to Asian or European Handicaps. Thus, when choosing this type of bet, understand that the chance of winning is generally lower.
Analyzing, evaluating, and predicting the outcome of a match between two strong teams is no easy task. Therefore, you should spend time learning and applying betting experience to see which strategies work best.
Here are some expert-recommended tips from W88 for maximizing your chances:
1. Don’t Place Bets Too Early
beautiful football referee girl name w88 advises against betting too early. The odds for level ball handicaps can change rapidly, so it’s best not to place your bet before the match starts. Instead, observe the first 15 minutes of the match to get a more objective view of the teams' performance. After this period, it’s still not too late to place your bet.
2. Prioritize Betting on the Home Team
As the saying goes: "Right time, right place, right people" — this applies well to level ball handicaps. Since both teams have similar strength and form, luck and home advantage can be deciding factors.
Playing on home turf often boosts the home team's confidence and performance, making it more likely they'll edge out a win. So, when placing a level ball bet, give priority to the home team.
Additionally, if the home team scores first, the odds may shift, and the away team might end up giving a 0.25 goal handicap. At that moment, placing a bet on the home team gives you a strong chance of winning.
3. Bet on the Team with Better Form
Besides choosing the home team, you should also favor teams with consistently strong performance. When betting on level ball handicaps, focus on teams that are high on the leaderboard and showing good form. Avoid betting on teams that are struggling, as they are more likely to lose.
Remember, mastering this type of bet doesn't happen overnight. You need experience and frequent betting practice to improve your decision-making speed and accuracy.
Key Notes Before Betting on Level Ball Handicap
While the gameplay may seem simple, level ball handicap bets are difficult to win. By combining the above tips with the following notes, you can avoid unnecessary losses:
Research the Teams Thoroughly
This applies not only to level ball handicaps but to all types of bets. You should investigate the following data about each team:
Recent form
Match and tournament history
Injury list
Head-to-head record
Coach profiles
Home/away performance
With this information, you’ll be better equipped to make informed betting decisions, increasing both efficiency and accuracy.
Don’t Bet Based on Emotion
Betting based on personal bias or favoritism only increases the risk of losing. Your favorite team may not always be in a favorable position. Emotional betting will hurt your chances, so even if a team is your idol, don’t blindly choose them.
Split Your Betting Budget
Whether you're a novice or a seasoned bettor, it’s best to divide your betting budget into smaller portions. This approach increases your chances of winning and minimizes losses.
Now you know what a level ball handicap is, its key features, and valuable tips for betting successfully. Although this type of bet offers lower odds of winning compared to others, it's simple to understand and easy to apply. If you follow the advice shared by W88 in this article, your chances of betting accurately and effectively will significantly improve.
