 Forum de l'association French-Drift-Community • Consulter le sujet - U4GM - How to Get and Use Beast Claw Items in Elden Ring
Message par ArcaneHaze » 03 Mai 2025, 05:36
In Elden Ring, Beast Claw items offer a unique and powerful way to unleash bestial rage against your enemies. These faith-scaling offensive tools are especially effective for hybrid builds that favor aggression and close-range devastation. In this guide, we’ll walk you through how to obtain and effectively use Beast Claw items, giving you a clear advantage in both PvE and PvP. Whether you're collecting Elden Ring items through gameplay or looking to buy Elden Ring items XBOX, this article covers everything you need to know.
What Are Beast Claw Items?
Beast Claw items refer to incantations and tools tied to Gurranq, the Beast Clergyman. These incantations, like Beast Claw and Bestial Sling, are designed to deliver quick, high-damage spells that scale with Faith and Strength. They can stagger enemies, clear mobs, and apply solid pressure in PvP scenarios.
These items are part of the “Bestial Incantations” category, known for their fast cast times and minimal Faith requirements, making them suitable for early- and mid-game builds.
How to Get Beast Claw Incantations
To access Beast Claw items, you'll need to interact with Gurranq, the Beast Clergyman:
1. Find the Bestial Sanctum
How to Reach: After giving the first Deathroot to D in Roundtable Hold, he’ll mark the Sanctum on your map. Use the teleporter north of the Third Church of Marika in Limgrave to reach it safely.
2. Feed Gurranq Deathroot
Every time you give Gurranq a Deathroot, he rewards you with a bestial item.
You can find Deathroots in dungeons that have undead bosses, like Tibia Mariners and Black Knife Catacombs.
3. Obtain Beast Claw
Reward: Given after the sixth Deathroot is turned in.
Requirements: 8 Faith.
Effect: Sends a wide, shockwave-like claw attack in front of the caster, ideal for crowd control and PvP zoning.
Other Useful Bestial Incantations
Alongside Beast Claw, consider these supporting incantations for a complete bestial setup:
Bestial Sling: A fast, shotgun-style burst of rocks with incredible stagger potential.
Stone of Gurranq: Throws a massive rock; higher cost, but great poise damage.
Beast Claw Greathammer: A weapon that synergizes well with the spell theme.
These are also obtained from Gurranq or by progressing through Deathroot deliveries.
How to Use Beast Claw Effectively
PvE Tips:
Use Beast Claw to hit multiple enemies at once during invasions or dungeon runs.
Cast just outside of melee range to avoid incoming attacks while applying constant pressure.
Combine with a weapon that scales with Strength/Faith for synergy.
PvP Tips:
Beast Claw is great for punishing roll catches or flushing out enemies from behind cover.
Alternate between Bestial Sling and Beast Claw for combo pressure.
Use a faster casting seal like the Clawmark Seal to reduce animation time.
Recommended Build for Beast Claw Use
Primary Stats: 20–30 Faith, 20+ Strength.
Seal: Clawmark Seal (boosts bestial incantations).
Armor: Medium armor for mobility, such as the Raging Wolf Set.
Talisman: Flock’s Canvas Talisman, Faithful’s Canvas Talisman.
This build gives you flexibility in both spell casting and melee combat, allowing for devastating chain attacks and pressure.
Buy Beast Claw Items Instantly on XBOX
If you missed a Deathroot or simply want to skip the farm, you can buyElden Ring items XBOX from trusted vendors to get the Beast Claw and supporting gear right away. Make sure to choose reliable platforms that guarantee quick delivery and account safety, so you can focus more on playing and less on grinding.
Beast Claw items in Elden Ring bring a feral edge to any Faith-based or hybrid build. They're fast, effective, and fit naturally into aggressive playstyles. Whether you earn them through Gurranq’s questline or buy Elden Ring items XBOX to get right to the action, mastering Beast Claw usage will help you dominate everything from dungeon mobs to invading players.
ArcaneHaze
Message(s) : 8
Utilisateur(s) parcourant ce forum : Baidu [Spider] et 1 invité
