 Forum de l'association French-Drift-Community • Consulter le sujet - What Is the Indonesian Odds Format? How to Read It Correctly
Message par wintips123 » 12 Avr 2025, 06:41
What Is the Indonesian Odds Format? How to Read It Correctly Like a True Football Betting Enthusiast
Compared to well-known odds types like Malaysian and Hong Kong odds, Indonesian odds seem to be less popular.
So, is there anything interesting about Indonesian football betting odds? Let’s explore with Wintips.
What Are Indonesian Odds?
Indonesian odds are a unique and attractive form of football betting odds, but still relatively unknown to many. Although they’ve been around for quite some time, most Vietnamese players still don’t fully understand them, leading to low interest or attention.
Contrary to the belief that this odds type is hard to win, once you understand how it works, it can actually be a “goldmine” with high potential returns.
Indonesian odds share some similarities with Malaysian odds. They include both negative and positive odds, and use 1.00 as the standard unit. However, there are also some notable differences.
For example: When betting with Indonesian odds, if you lose, you might lose more than your original stake—especially if you bet on the favorite. However, with higher risk comes higher reward.
If you win, you can receive a payout larger than your original stake (unlike the 1:1 payout ratio of many other odds formats).
So, if you're someone who’s willing to take risks for bigger wins, Indonesian odds might be the right choice for you.
In short, Indonesian odds share some traits with Hong Kong and Malaysian odds but come with higher risks—balanced by the potential for big wins, which is exactly what many bettors are after.
Note: This odds format isn’t very popular in Vietnam yet.
Key Features of Indonesian Odds
When placing bets, you can find Indonesian odds by selecting them from the odds format menu at any bookmaker legit site.
Once selected, you’ll see two main types:
Positive odds (for the underdog)
Negative odds (for the favorite)
Both use 1.00 as the unit.
With positive odds, if you win, your profit will be greater than your stake.
With negative odds, if you win, your profit will be less than your stake.
Tip: Be sure to change the odds format to Indonesian in the top-right corner of the odds table.
How Are Indonesian Odds Calculated?
This is one of the most important things to understand before placing a bet. Here's how they’re calculated:
(1) Positive Indonesian Odds (+)
Formula:
java
Sao chépChỉnh sửa
Stake × Odds=Profit
This format is popular because it offers high payouts. But of course, high reward comes with high risk. If you're a risk-taker, this might be for you.
Example:
In a match between Chelsea and Liverpool, the odds for "Over 1.5 goals" is -1.25. If you bet 50,000 VND and the match ends with more than 1.5 total goals, your profit is:
Sao chépChỉnh sửa
50,000 × 1.25=62,500 VND
Your total payout would be:
Sao chépChỉnh sửa
62,500 (profit) + 50,000 (stake)=112,500 VND
(2) Negative Indonesian Odds (-)
Formula:
java
Stake ÷ Odds=Profit
Compared to positive odds, negative odds give lower profits, but they also involve less risk. If your strategy is about steady wins rather than big risk, negative odds could be the better choice.
Tips for Betting with Indonesian Odds
Here are some expert tips you shouldn't miss:
1. Be Sure of Your Bet
Since this odds type can lead to high losses when you’re wrong, it’s important to do thorough research before placing your bet. Indonesian odds are not for lazy or timid bettors. Be confident in your decision before committing.
2. Stay Focused When Analyzing Odds
Indonesian odds can sometimes seem less favorable, but every bet has its own opportunity. Don’t be misled by the numbers. Trust your research and analysis to make smart decisions.
3. Choose the Right Timing
For best results, place your bets at least 30 minutes before kickoff. This gives you enough time to analyze the odds without sudden last-minute changes affecting your decision.
4. Favor the Stronger Team
Before betting, always research the teams’ strengths, form, and current performance. If you're new to betting, it’s best to go with the stronger team to avoid losses in your first wagers.
Where to Bet with Indonesian Odds
You can find Indonesian odds at reputable betting sites in peru like:
188BET
VN88
FB88
DAFABET
Letou
M88
W88
...and more.
That wraps up the essential information about Indonesian odds. Hopefully, this guide has helped you understand this lesser-known but exciting betting format—and maybe even brought you one step closer to success in your football betting journey!
Message(s) : 94
Re: What Is the Indonesian Odds Format? How to Read It Corre
Message par Jayden » 14 Avr 2025, 17:17
Mitolyn Reviews is a revolutionary mitochondrial support supplement that works at the cellular level to restore energy and vitality. By repairing damaged mitochondria, stimulating the creation of new ones, and protecting cells from stress and inflammation, it enhances metabolism, improves overall health, and delivers lasting results when other solutions don’t work.
Jayden
Message(s) : 187
Message par xurple » 04 Juin 2025, 23:35
Message(s) : 87399
