 Forum de l'association French-Drift-Community • Consulter le sujet - What is a Level Ball (Draw No Bet) Handicap? Tips for Winnin
Message par wintips123 » 11 Avr 2025, 06:38
What is a Level Ball (Draw No Bet) Handicap? Tips for Winning with This Bet Type
Although the term level ball handicap is no longer unfamiliar in the world of football betting, many participants still don’t fully understand what it actually means. In the following article, Wintips will share some key information to help you better grasp this type of bet. Let’s take a look!
What is a Level Ball Handicap?
Today, many football bettors wonder what the level ball handicap is. Also known as the 0 handicap or draw no bet, this is one of the most common odds types in Asian Handicap betting.
When this type of bet appears, it means the two teams are fairly evenly matched—there is no significant difference in form, strength, or performance. Alongside this, there’s also the 0.25 handicap (quarter-ball), which is very similar. However, the main difference is that with the 0.25 handicap, your stake is not refunded in case of a draw.
Key Characteristics of the Level Ball Handicap
Unlike other handicap odds, the level ball handicap does not divide teams into favorites (upper hand) and underdogs (lower hand). Instead, both teams are considered equal in strength.
This type of handicap is often seen in combination with other odds like:
0.25 handicap
Live (in-play) betting
0.5 handicap, etc.
Example:
In a match between Liverpool and Real Madrid, the bookmaker offers a level ball handicap. When you bet using this odds type, you may encounter the following outcomes:
Scenario 1: You bet on Real Madrid to win. If Real wins, you receive your payout according to the odds provided by the bookmaker.
Scenario 2: You bet on Real Madrid, but Liverpool wins. You lose your full stake.
Scenario 3: You bet on either team, but the match ends in a draw. Your original stake is refunded.
Expert Tips for Winning with Level Ball Bets
To increase your chances of winning with this bet type, you’ll need to develop strong betting skills and strategies. Here are some expert tips worth noting:
1. Bet Small on the Team with Lower Odds
In level ball bets, the payout odds (conversion rate) are crucial. You’ll often notice a disparity in odds even when both teams are deemed equal in strength.
This is because bookmakers still have subtle evaluations of which team is more likely to win. So, betting on the team with lower payout odds (the team the bookmaker subtly favors) may increase your chances of success.
2. Choose the Home Team
In football long shot technique, home advantage is a major factor in match outcomes. Playing at home boosts a team’s morale, energy, and confidence—thanks to fan support and familiarity with the pitch.
Therefore, when placing a level ball bet, opting for the home team often gives you a better chance of winning.
The information above is what we’ve gathered and want to share with you. Hopefully, it has helped you clearly understand what a level ball (0 handicap) bet is and given you useful tips to make the most of it.
Good luck, and may your bets be successful!
Re: What is a Level Ball (Draw No Bet) Handicap? Tips for Wi
Message par xurple » 05 Mai 2025, 01:05
Message par xurple » 04 Juin 2025, 23:30
