 Forum de l'association French-Drift-Community • Consulter le sujet - U4GM - POE 2: How to Test Which Build Earns More Chaos Using
Message par ElizaDrifter » 02 Avr 2025, 03:59
When it comes to maximizing your poe 2 currency gains in Path of Exile 2, choosing the right build is crucial. One of the best ways to determine which build is more profitable is by running A/B map tests. This method allows you to compare two different builds under controlled conditions to see which one generates more Chaos Orbs and other valuable drops. Here’s how you can conduct an effective A/B test for your builds.
Why A/B Testing Matters
Different builds excel at different content. Some are great at clearing maps quickly, while others are better at bossing or handling high-tier content. By comparing two builds using the same map layout and modifiers, you can objectively measure which one earns more poe 2 currency per hour.
Step 1: Choose Two Comparable Builds
Select two builds you want to test. Ideally, they should have similar investment levels (gear, gems, passives) to ensure a fair comparison. For example, you might compare a fast-clearing Arc Witch against a high-single-target-damage Tornado Shot Ranger.
Step 2: Standardize Your Testing Conditions
To get accurate results, you need to control variables:
Map Tier & Modifiers: Run the same map (e.g., T16 Dunes) with identical modifiers.
Sextants & Scarabs: Use the same setup for both test runs.
Time Limit: Allocate a fixed time (e.g., 30 minutes) for each build.
Loot Filter: Use the same filter to ensure consistent loot pickup.
Step 3: Track Your Earnings
After each run, record:
Total Chaos Orbs and other poe 2 currency drops.
Valuable items (Divination Cards, Uniques, etc.).
Time taken to complete the map.
Step 4: Analyze the Results
Compare the average poe 2 currency per hour for each build. Consider:
Which build clears faster?
Which one has better sustained damage for tougher modifiers?
Are there significant differences in rare drops or boss loot?
Step 5: Optimize & Repeat
If one build performs significantly better, focus on optimizing it further. If results are close, run additional tests to confirm.
A/B testing maps is a reliable way to determine which build is more profitable in POE 2. By following a structured approach, you can maximize your poe 2 currency farming efficiency and invest in the best build for your playstyle. Happy grinding!
ElizaDrifter
Message(s) : 3
Re: U4GM - POE 2: How to Test Which Build Earns More Chaos U
Message par xurple » 05 Mai 2025, 00:10
Message par xurple » 04 Juin 2025, 22:35
Utilisateur(s) parcourant ce forum : Bing [Bot] et 2 invité(s)
