 Forum de l'association French-Drift-Community • Consulter le sujet - What is Over/Under Betting? How to Read Over/Under Odds in F
Message par wintips123 » 18 Mars 2025, 06:23
What is Over/Under Betting? How to Read Over/Under Odds in Football
Professional football players are certainly no strangers to Over/Under betting. However, many beginners still find this type of bet unfamiliar. So, what is Over/Under betting, and how do you read the odds? Let’s explore this topic with win tips bet in the following article.
Nowadays, football betting has become incredibly diverse and is generally divided into two main categories: main bets and side bets. Alongside Asian Handicap and European Odds, Over/Under betting is also a primary betting option found in every match.
The popularity of football betting is growing due to the simplicity of this betting method and its attractive rewards.
Definition of Over/Under Betting
Over/Under betting is a widely used form of betting, especially during football seasons. This type of bet involves predicting the total number of goals in a football match by betting whether the total will be over or under the number set by the online bookmaker list.
Over (Tài): The total number of goals is greater than the bookmaker’s set number.
Under (Xỉu): The total number of goals is less than the bookmaker’s set number.
Example
A football match consists of two halves:
The first half ends 1 – 2
The second half ends 3 – 5
Thus, the total number of goals:
First half: 3 goals
Second half: 8 goals
Total: 11 goals
If the bookmaker sets the Over/Under line at 7 goals:
Over bettors win if they placed a bet on more than 7 goals.
Under bettors lose if they placed a bet on less than 7 goals.
Understanding how to read Over/Under betting odds is essential for making accurate bets. Below are some of the most common Over/Under odds offered by bookmakers:
Over/Under 1.5 – 2
If the total goals in the match are 0 or 1Under wins, Over loses.
If the total goals are exactly 2Over wins half, Under loses half.
If the total goals are 3 or moreOver wins, Under loses.
Over/Under 2
If the total goals are 0 or 1Under wins, Over loses.
If the total goals are exactly 2Bet is refunded.
Over/Under 2 – 2.5
If the total goals are exactly 2Over loses half, Under wins half.
Over/Under 2.5
If the total goals are less than 2Under wins, Over loses.
Over/Under 2.5 – 3
If the total goals are 0, 1, or 2Under wins, Over loses.
If the total goals are exactly 3Over wins half, Under loses half.
If the total goals are 4 or moreOver wins, Under loses.
Over/Under 3
If the total goals are exactly 3Bet is refunded.
Over/Under 3 – 3.5
If the total goals are exactly 3Over loses half, Under wins half.
Over/Under 3.5
If the total goals are less than 3Under wins, Over loses.
Key Considerations for Over/Under Betting
1. Assess the Match Carefully
When placing Over/Under bets, analyzing the gameplay of both teams is crucial. The way teams play significantly impacts your chances of winning.
If both teams focus on attacking, the match is more likely to have many goals → Bet on Over.
If both teams focus on defense, the game is likely to have fewer goals → Bet on Under.
2. Betting Timing Matters
The match should start after the 10th minute before placing an Over/Under bet.
If a goal is scored in the first 15 minutes, betting on Over becomes more favorable.
If no goals are scored in the first 15 minutes, betting on Under might be a safer choice.
3. Take Advantage of Promotions
Many bookmakers, including oddslot football prediction site W88, offer special promotions for Over/Under bets. If you’re looking for a trusted betting platform, consider checking out W88.
In our previous articles, we have provided valuable information related to football betting strategies. We hope you can use this knowledge effectively at W88 to increase your chances of winning. Good luck!
Re: What is Over/Under Betting? How to Read Over/Under Odds
Message par xurple » 04 Mai 2025, 22:57
Message par xurple » 04 Juin 2025, 21:22
