 Forum de l'association French-Drift-Community • Consulter le sujet - Guide on How to View Football Betting Odds Simplified
Message par rebornn07777 » 24 Mai 2024, 06:21
Football betting odds, also known as betting odds or odds ratios, are crucial in assessing teams for placing bets. Therefore, players must carefully view these odds on reputable websites. Let's explore super football tips how to view football betting odds simply through the following article.
Viewing Asian Handicap Football Betting Odds
Asian Handicap football betting odds, also known as Asian odds or Handicap in English, typically rely on the final goal tally to determine the winning or losing team.
For Asian Handicap football betting odds, players need to note that the team displayed in red is the stronger team, also known as the upper team. The team displayed in black is the weaker team, also known as the lower team.
Here is a guide on how to view football betting odds simply and understandably:
1. ½ Betting Odds or ½ Handicap (0.5)
With these betting odds, the upper team will give a 0.5 (half) goal handicap to the lower team. If the final result is a draw, the lower team will win.
If the upper team wins, those who placed bets on the upper team will win the entire amount, and vice versa.
2. ¾ Betting Odds or ¾ Handicap (0.75)
For these betting odds, when a player sees the odds of 0.75, they need to understand that the upper team is giving a 0.75 handicap to the lower team.
If the upper team wins by a margin of two goals or more, those who bet on the upper team will win the entire amount. If the upper team wins by only one goal, those who bet on the upper team will win half the amount, and those who bet on the lower team will lose half the amount.
If the match ends in a draw or if the upper team loses, those who bet on the upper team will lose the entire amount.
3. 1 Betting Odds or 1 Handicap (1 Draw)
When viewing the betting odds table, if the odds are 1, it means that if the upper team wins by only one goal difference, the bet will be refunded. If the upper team wins by a margin of two goals or more, the player will win the entire amount they bet on the upper team.
If the match result is a draw or if the upper team loses, those who bet on the upper team will lose the entire amount.
4. 1 ¼ Betting Odds or 1 ¼ Handicap (1.25)
When you see these betting odds, it means that if you bet on the upper team and the upper team wins by only one goal difference, you will lose half the amount you bet.
If the upper team wins by a margin of two goals or more, the player who bet on the upper team will win the entire amount.
5. 1 ½ Betting Odds or 1 ½ Handicap (1.5)
These betting odds indicate that if you bet on the upper team and the upper team draws, loses, or wins by only one goal difference, you will lose the entire amount.
Access Now : what is asian handicap
The odds ratio 1 ¾, also known as a 1 ¾ handicap (1.75), poses significant considerations for bettors. With this odds ratio, players must carefully assess whether they believe the favored team will win convincingly. Betting on the favored team will result in a full payout only if that team wins by a margin of three goals or more. If the favored team wins by a two-goal margin, the better receives only half of the payout. If the favored team wins by one goal, draws, or loses, the better loses the entire bet.
The 2 odds ratio, or 2 handicap, typically appears when the favored team is significantly stronger than the underdog. With this ratio, players break even if they bet on the favored team and it wins by a two-goal margin. If the favored team wins by three goals or more, the better receives the full payout. If the favored team wins by one goal, draws, or loses, the better loses the entire bet.
The 0 odds ratio, or draw (level handicap), involves no handicap. Therefore, if both teams draw, the bookmaker refunds the bet. If a player bets on a team and that team wins, the player wins the entire bet; conversely, if the team loses, the player loses the entire bet.
Reading the odds for Asian football betting is simpler than for Asian Handicap. Players need only focus on the match result: win, lose, or draw. This type of bet, often referred to as 1×2, is beloved by many newcomers to betting.
Understanding the odds for Asian football betting is straightforward; simply look at the odds table and find the 1×2 column, where you'll see the odds for winning, losing, or drawing.
For example, if you bet 100 units on the favored team with odds of 2, and the favored team wins, you receive 100×2= 200 units. If you bet 100 units on a draw with odds of 3, and the match ends in a draw, you win with a payout of 100×3= 300 units. If you bet 100 units on the underdog with odds of 1.5, and the underdog loses, you win 100×1.5= 150 units.
Note: Betting incorrectly on the match result results in the loss of the entire bet. Specifically, if you bet 100 units on the favored team but they lose, you lose the entire amount.
Asian football betting odds can be placed for either the first half or the full match.
These are some betting tips best sites insights from Wintips on understanding football betting odds. Hopefully, this article has been helpful for you when analyzing odds on betting tables.
rebornn07777
Message(s) : 32
Re: Guide on How to View Football Betting Odds Simplified
Message par xurple » 17 Fév 2025, 13:16
Message par xurple » 04 Mars 2025, 13:50
Message par xurple » 04 Mai 2025, 18:41
Message par xurple » 04 Juin 2025, 17:07
