 Forum de l'association French-Drift-Community • Consulter le sujet - Asian Handicap Corners - The most accurate corner betting ex
Message par rebornn07777 » 20 Fév 2024, 06:42
In today's football betting scene, there are countless types of bets that vary depending on the match situation. These football betting types are usually divided into two categories: Main bets and side bets. Main bets include over/under bets, handicap bets, or Asian handicap bets, while side bets cover score bets, yellow cards, red cards, etc. Currently, one of the most popular side bets is the Asian Handicap Corners, with nearly the same number of participants as the main bets. Let's see what Wintips has to say about this football tips predictz interesting betting option.
What is Asian Handicap Corners?
Asian Handicap Corners, also known as Corners or Corner bets, is the latest online betting trend in the football betting industry. With this type of bet, players are not concerned about which team wins or loses or the number of goals conceded in the match. The main focus is on the number of corner kicks that both teams have executed in the match you are betting on. Other corner-related factors to consider include which team takes the first corner kick and which team takes the last corner kick, etc.
Depending on the nature of the football match and the characteristics of each team, reputable bookmakers will offer different types of corner bets. Moreover, the odds for corner bets will correspond to each type of bet. The corner betting odds may vary from one bookmaker to another.
Some common types of Asian Handicap Corners bets
Similar to other football betting types offered by leading bookmakers today, Asian Handicap Corners bets come in various forms and playing styles. Below are some common types of bets:
Total corners over/under for the whole match: This type of bet predicts the outcome for the entire match. Players must choose whether the total number of corners will be over or under the odds set by the bookmaker for each match.
When placing bets on this type of Asian Handicap Corners, the under option means that the number of corners taken in the match will be less than the odds set by the bookmaker. On the other hand, the over option predicts that the total number of corners taken in the match will be greater than the odds set by the bookmaker. Additionally, reputable bookmakers may offer players the option to bet on total corners over/under for either the first or second half, although this type of bet is less common.
Full match Asian Handicap Corners: With this type of bet, each bookmaker will offer different handicap odds depending on each match. Players need to choose the team that is handicapped in terms of corner kicks. Based on the number of corner kicks taken throughout the match and the handicap odds, players can determine the winning or losing team.
Find out more : what's an asian handicap bet
Corner kick handicap 1×2
The way to play this type of bet is quite simple, similar to the Asian handicap bet in football betting. With the corner kick 1×2 handicap, players have three choices: Win – Draw – Lose, depending on the betting choice, the odds of winning the bet from different bookmakers will vary.
Odd/Even Corner Kick Handicap
This is a straightforward betting option where players bet on whether the number of corner kicks performed in the match is odd or even. For example, if there are 10 corner kicks in the entire match, and the player bets on even, they win, and vice versa.
First Corner Kick Handicap
This bet requires players to predict which team will execute the first corner kick in the match.
Last Corner Kick Handicap
In this type of bet, bettors must analyze and predict which team will execute the last corner kick in the match.
Tips for Winning Corner Kick Handicap Bets
If players want to win consistently in corner kick handicap betting, they should follow these tips:
Thoroughly research pre-match information
Before participating in corner kick handicap betting, it's essential to research and analyze specific information such as:
The number of corner kicks by each team in their recent matches.
Investigate whether there's a difference between home and away matches in terms of corner kicks.
Assess the capabilities of both teams; stronger teams usually earn more corner kicks.
Bad weather conditions can lead to more corner kick situations.
Be decisive in betting decisions
When playing first corner kick or last corner kick bets, it's crucial to be decisive. Since corner kicks happen quickly, the odds usually favor both teams. If you have made an accurate prediction, it's best to place your bet immediately.
This article daily betting tips app by Wintips has provided you with a clearer understanding of what corner kick handicap betting is and the most effective tips for corner kick handicap betting. To increase your chances of winning, visit our website for the latest odds and place your bets now.
rebornn07777
Message(s) : 32
Re: Asian Handicap Corners - The most accurate corner bettin
Message par xurple » 04 Mars 2025, 12:41
Message par xurple » 04 Mai 2025, 17:32
Message par xurple » 04 Juin 2025, 15:58
