Marksman leveling in Season 10 feels smoother when Frag Grenade and Vault are treated as a connected early-game package rather than two unrelated buttons. Players preparing their route around Hero Siege Items can use this pairing to clear crowded rooms quickly while keeping enough spacing to survive until Gunner Drone becomes the primary source of pressure.
Frag Grenade Creates the Early Clearing Rhythm
Frag Grenade is the direct answer to the crowded encounters that define the first stretch of a Marksman run. Its area coverage lets the class remove clustered enemies without needing to stand still and trade hits at close range. A well-placed throw also softens durable targets before basic attacks finish them.
The skill is especially valuable in narrow paths, doorways, and objective rooms where enemies naturally gather. Instead of chasing every target, the Marksman can pull a group into one area, throw the grenade, and continue moving. This produces a faster rhythm than relying on single-target shots alone.
Early points should therefore favor Frag Grenade when its next rank noticeably improves clearing pace. It remains the main damage tool during the period before Drone access, giving the character a dependable way to deal with dense waves and keep experience gains steady.
Vault Is More Than an Escape Button
Vault provides mobility, but its real leveling value is control. It lets the Marksman choose where a fight happens, recover space after a grenade throw, and avoid losing time while surrounded. That freedom matters because the class performs best when enemies remain in front rather than on every side.
Use Vault proactively to cross dangerous ground, reposition behind a pursuing pack, or move through a lane after Frag Grenade has opened it. The skill can also preserve momentum between groups. A short movement burst may save more time than stopping to remove every remaining enemy.
One early investment in Vault is usually enough to establish this pattern. Additional ranks become attractive only if the current area repeatedly forces close-range pressure or if the reduced downtime clearly improves movement through the map. Otherwise, save the heavier investment for skills that will define the next stage.
The Moment Gunner Drone Changes the Build
The shift should begin on the first level where Gunner Drone becomes available. Take one point immediately, even if Frag Grenade is still carrying most of the visible damage. That first point starts the transition by adding persistent fire while the Marksman continues throwing grenades and using Vault for positioning.
After unlocking it, place the next major skill points into Gunner Drone rather than continuing to raise Vault. Frag Grenade can still receive points when a rank gives a meaningful clearing improvement, but Drone should become the priority because its sustained output grows better as enemies become tougher and fights last longer.
Vault does not disappear from the setup after this change. It becomes the tool that keeps the drone effective: reposition to maintain a clean firing lane, evade pressure that would interrupt movement, and guide enemies through the area where both grenade impact and drone fire can connect.
A Clean Mid-Leveling Hand-Off
The strongest transition is not an abrupt replacement of the early kit. Frag Grenade continues to erase packed enemies, Vault keeps the character safe and efficient, and Gunner Drone adds the sustained presence that early leveling lacks. Together, they prevent the awkward gap that can appear when enemies begin surviving the opening burst.
By the mid-game, the desired feel is simple: throw Frag Grenade into the largest cluster, Vault into a safer angle when needed, and let Gunner Drone work while the next group approaches. Players looking for Hero Siege Items for sale should keep this skill timing in mind, since a steady Drone-focused transition supports a much more consistent Marksman progression.
